ÇÖZÜLDÜ I need ATI Mobility Radeon HD 550v/4650 for 10.12.6
kkaaro
17 Kas 2017
14
Alguien que me ayude.
Mi gráfica es ATI Mobility Radeon HD 550v/4650.
Siempre he encontrado este kext para yosemite, el capitan, sierra 10.12, sierra 10.12.4.
El último que tengo es ATI Radeon HD 4650 for Sierra 10.12.4 beta 5 (16E183b) - ATI - osx86.net
Pero mi problema es que no lo encuentro para 10.12.6 ni para 10.13.1. Es mi único problema. Este existe? cómo puedo obtenerlo a partir de otras versiones? Alguien que me ayude o me explique por favor.
Perdón por el idioma, soy de México. Dejo mi mensaje en español y en inglés.
Somebody help me.
My graphic is ATI Mobility Radeon HD 550v / 4650.
I have always found this kext for yosemite, the captain, sierra 10.12, sierra 10.12.4.
The last one I have is ATI Radeon HD 4650 for Sierra 10.12.4 beta 5 (16E183b) - ATI - osx86.net
But my problem is that I do not find it for 10.12.6 nor for 10.13.1. It's my only problem. Does this exist? How can I get it from other versions? Someone to help me or explain me please.
Sorry for the language, I'm from Mexico. I leave my message in Spanish and English
7,518
What is the DEV & VEN-ID of your GPU?
7,518
There is no guarantee, but you can try the kext files I share below.
Test_Drive.zip
I've added your Dev&Ven ID to 10.13.1 AMD4600Controller.kext.
PS: Don't forget the Rebuild Cache after install.
Tepkiler: linepower
kkaaro
17 Kas 2017
14
Thank you very much. This works. When installing 10.13.1 on the first reboot I have kernel panic. But I enter in safe mode and delete ATIRadeonX2000.kext.
Do you have the AMD4600Controller.kext for 10.12.6? I would really appreciate it.
Thanks
7,518
kkaaro
17 Kas 2017
14
The first kext files work in 10.13.1, but not in 10.12.6.
The second kext files work on 10.12.6.
Thank you very much, how do you get them?
7,518
kkaaro
17 Kas 2017
14
Hello, I am again asking for help to find the kext for my ATI Mobility Radeon HD 550v / 4650, VEN-ID: 1002, DEV: 9480. Now for High Sierra 10.13.3 or High Sierra 10.13.4.
Thank you very much and greetings
7,518
Try this;
Tepkiler: kkaaro
7,518
The GPU isn't supported in macOS.
kkaaro
17 Kas 2017
14
The laptop that I have in mind is a Dell Inspiron 5567, the specifications mentioned Graphics: Intel Graphic 620 4 Gb and AMD Radeon R7 M445 4 Gb dedicated. I do not know if it's a dual graphics.
What graphics do you recommend for me to work on Mac OS?
7,518
You can not use dual graphics on a Hackintosh. You can only use the HD 620 graphic.
kkaaro
17 Kas 2017
14
I should think nvidia or someone else that you recommend me please. That is of intermediate price. Thank you. regards
7,518
7,518
ImTheFunny
14 Tem 2018
Hi montezuma, do you have the ATI Mobility Radeon HD 4650 for the El Captain VEN_1002&DEV_9480 ?
