macOS için shell script nasıl oluşturabilirim? Bulduğum bazı dosyalar var bunları çift tıklama ile script olarak kullanmak istiyorum.
Örneğin bu scripti:
Örneğin bu scripti:
#!/bin/bash
# Mount EFI
# @cecekpawon 10/24/2015 14:13 PM
# thrsh.net
gVer=1.6
gTITLE="Mount EFI v${gVer}"
gUname="cecekpawon"
gME="@${gUname} | thrsh.net"
gBase="OSXOLVED"
gRepo="https://github.com/${gUname}/${gBase}"
gRepoRAW="https://raw.githubusercontent.com/${gUname}/${gBase}/master"
gScriptName=${0##*/}
isdone() {
exit
C_MENU="\e[36m"
C_BLUE="\e[38;5;27m"
C_BLACK="\e[0m"
C_RED="\e[31m"
C_NUM="\e[33m"
gHEAD=`cat <<EOF
${C_MENU}============================================
${C_BLUE}${gTITLE} ${C_MENU}: ${C_RED}${gME}
${C_MENU}Usages\t: ${C_BLUE}./${gScriptName} ${C_MENU}[${C_NUM}-Options${C_MENU}]
${C_MENU}\t\t: ${C_BLUE}./${gScriptName} ${C_NUM}-aou
${C_MENU}Options\t: ${C_NUM}-a${C_MENU}] auto-mount
${C_MENU}\t\t: ${C_NUM}-o${C_MENU}] auto-open
${C_MENU}\t\t: ${C_NUM}-u${C_MENU}] update-scripts
${C_MENU}--------------------------------------------
${C_MENU}Inspiration: Clover Configurator, #longlive!
${C_MENU}--------------------------------------------${C_BLACK}\n\n
EOF`
gMSG=`cat <<EOF
Please die!\n
EOF`
gAuto=0
gOpen=0
gUpdate=0
aDisk=()
aPar=()
aLabel=()
i=0
tabs -6
clear && printf "${gHEAD}"
aEFI=($(diskutil list | grep EFI | grep -o -e disk[[:digit:]]*s[[:digit:]]*))
gEFITotal=${#aEFI[@]}
if [[ $gEFITotal -eq 0 ]]; then
echo "Zero EFI partition detected!"
isdone
fi
while getopts :aAuUoO gOpt; do
case "${gOpt}" in
[aA]) gAuto=1;;
[uU]) gUpdate=1;;
[oO]) gOpen=1;;
esac
done
if [[ $gUpdate -ne 0 ]]; then
echo "Looking for updates .."
gTmp=$(curl -sS "${gRepoRAW}/versions.json" | awk '/'$gScriptName'/ {print $2}' | sed -e 's/[^0-9\.]//g')
if [[ $gTmp > $gVer ]]; then
echo "Update currently available (v${gTmp}) .."
if [[ -w "${0}" ]]; then
gBkp="${0}.bak"
gTmp="${0}.tmp"
echo "Create script backup: ${gBkp}"
curl -sS "${gRepoRAW}/${gScriptName}" -o "${gTmp}"
gStr=`cat ${gTmp}`
if [[ "${gStr}" =~ "bash" ]]; then
echo "Update successfully
cp "${0}" "${gBkp}" && mv "${gTmp}" "${0}" && chmod +x "${0}"
read -p "Relaunch script now? [yY] " gChoose
case "${gChoose}" in
[yY]) exec "${0}" "${@}";;
esac
isdone
else
echo "Update failed
fi
else
echo "Scripts read-only
fi
else
echo "Scripts up-to-date!
fi
printf "\n"
fi
gStr=""
gStartup="$(diskutil info / | awk '/Identifier/' | grep -o -e disk[[:digit:]]*)"
printf "`cat <<EOF
Getting EFI disks ..
Choose one from available devices:
[${C_BLUE}#${C_BLACK}] is current startup disk!
[#]\t| Partition\t| Label
------+-----------+--------------------------\n
EOF`"
for gArg in "${aEFI[@]}"
do
gDevice=$(echo "${gArg}" | grep -o -e disk[[:digit:]]*)
gInfo=$(diskutil info "${gDevice}" | grep 'Media Name:' | sed -e 's/.*://;s/^ *//')
aPar+=("${gArg}")
aDisk+=("${gDevice}")
aLabel+=("${gInfo}")
C_HI=$C_BLACK
if [[ "${gStartup}" == "${gDevice}" ]]; then
C_HI=$C_BLUE
(($gAuto)) && gChoose=$i
fi
gStr+="[${C_HI}${i}${C_BLACK}]\t| ${C_HI}${gArg}${C_BLACK}\t| ${C_HI}${gInfo}${C_BLACK}\n"
let i++
done
printf "${gStr}\n"
((!$gAuto)) && read -p "Choose [#]: " gChoose
if [[ "${gChoose}" =~ ^[[:digit:]]+$ ]] && [[ $gChoose -lt $gEFITotal ]]; then
gDisk=${aDisk[$gChoose]}
gPar=${aPar[$gChoose]}
gLabel=${aLabel[$gChoose]}
gOEFI=$(df | grep "${gPar}")
(($gAuto)) && printf "Auto mount EFI on: ${gDisk} .."
printf "\nMounting: ${gPar} (on ${gLabel}) ..\n"
[[ ! -z "${gOEFI}" ]] && diskutil unmount "${gPar}"
diskutil mount "${gPar}"
mEFI=$(diskutil info "${gPar}" | grep 'Mount Point:' | sed -e 's/.*://;s/^ *//')
printf "Mounted on: ${mEFI} ..\n"
if [[ $gOpen -ne 0 ]]; then
printf "Auto open EFI directory ..\n"
open "${mEFI}"
fi
fi
#printf "${gMSG}"
isdone
# Mount EFI
# thrsh.net
gVer=1.6
gUname="cecekpawon"
gBase="OSXOLVED"
isdone() {
exit
C_MENU="\e[36m"
C_BLACK="\e[0m"
C_RED="\e[31m"
C_NUM="\e[33m"
gHEAD=`cat <<EOF
EOF`
gMSG=`cat <<EOF
Please die!\n
EOF`
gAuto=0
gOpen=0
gUpdate=0
aDisk=()
aPar=()
aLabel=()
i=0
tabs -6
isdone
fi
case "${gOpt}" in
[aA]) gAuto=1;;
[uU]) gUpdate=1;;
[oO]) gOpen=1;;
esac
done
gBkp="${0}.bak"
gTmp="${0}.tmp"
gStr=`cat ${gTmp}`
esac
isdone
else
echo "Update failed
fi
else
fi
else
fi
printf "\n"
fi
gStr=""
printf "`cat <<EOF
EOF`"
do
aPar+=("${gArg}")
C_HI=$C_BLACK
C_HI=$C_BLUE
fi
let i++
done
printf "${gStr}\n"
open "${mEFI}"
fi
fi
#printf "${gMSG}"
isdone
